Hi! Do you have a smoothing option for isosurface when rendering as ocean, whiy not have the same option when rendering normal liquids? I often can see the grid shape on the liquids unless I use killer high resolutions.
There is the Mesh Smooth option in the Rendering panel that affects the Ocean, Cap and Mesh render modes.
Apart from that, you can also smooth any channel from the Input panel, and this will work for all render modes, including isosuface, and also atmospheric.
the iso surface is smoothed only by the input panel "content smooth " option, it is not affected by the mesh smooth option because it's not a mesh in fact.
however, the iso surface is not able to work in ocean mode, so if you are using ocean, this means not iso surface is used and you can use the mesh option.
