Multy FollowPath RGB
  • Multy FollowPath RGB
    Is there any way setup several followpath to blend RGB?
    If I create 2 paths, one of them always does not stick to the path.
    Also I noticed if i create 2 sources with different RGB on same path one of them always fade out.
    currently the follow path has no limitation by distance, and this makes problematic to use two forces in one simulation, but we can add this option.
    ______________________________________________
    VRScans developer
      thank you for fast answer
      hope you add this option
