Fluid velocity frame blending crashing
  • Fluid velocity frame blending crashing
    Hello everyone!
    I have a 400-frame fluid sim that consistently crashes about 30% in. I think I've pinpointed the cause of the crash - I'm retiming my 200f sim in the scene by changing the time bend mode to 'cache index' under 'Input', animating the index to scale time within a 400f sequence. If I have 'Frame Blend' to 'Interpolation', no crash but undesirable results - if I set it to 'velocity' (for a smooth interpolation between sim frames), it eventually jacks my memory up until crashing (several frames into the interpolation blending). I can't preview viewport sequence, render or export the mesh as alembic without it crashing. If I resume render after a crash, it renders a few frames, runs out of memory and crashes again. Frame blending with velocity is killing my machine.
    At this point I can't render the mesh, I can't export the mesh... what can I do? Is this the kind of thing people use Krakatoa for, to retime? Would I then need to use Frost to mesh? I have no budget for additional tools, I would love to retime with Phoenix... How can I keep the memory from getting out of control until crash? Can I retime the sim data itself without using frame blending and messing with the input?
    3ds Max 2017, Vray 3.4, Phoenix FD 3
    Xeon E5-2650 2GHZ w/ 64 GB RAM
    Titan X
    Let me know what other information you need - Thank you for any guidance!
    Hello,
    Please don't use Velocity blending - change it back to Interpolation. We found and fixed a memory leak there and the fix will be in the nightlies when we make them open, hopefully in a couple of weeks.
    About retiming, I didn't understand if you are simulating liquids or fire/smoke - if you are retiming liquids, only changing settings in the Input panel would be enough and you wouldn't need the Velocity interpolation anyway. If you are retiming fire/smoke, then please check the docs site for more info on that - https://docs.chaosgroup.com/display/...time-scale,etc.
    Generally, the Velocity interpolation is slow and gives bad results anyway, so I'm thinking of removing it altogether.
    Cheers!
      Got it! Changed it back and I'm not seeing the popping mesh that I saw before... I don't know what I did wrong before, it could be 1 of 50 things, so many variables - maybe it was a lower res sim. Lower res usually generates a less smooth and shaky surface. Anyway, I captured a viewport sequence with no crash. I expect render to be just fine now.
      Thanks for the help! I'm always surprised how fast you guys reply to help via forum or email.
      Edit:
      Scene rendered no problem after ditching 'velocity' interpolation. No crashes, just glorious fluids!
        I have the same issue. Same scene happen only in my laptop, not the machine in the office (which is much powerful), so I thought it was a hardware problem. Tks for the reply.
