Hi there,
here is another setup I wanna try, when I have some spare time (which I don´tt right now, hence the post...:
I want to do some realistic earth-seen-from-space-shots. Originally I was considering using Vue for that, but after playing around with the demo I just didn´t feel like learning the package just for those couple of shots...
Also, since I have phoenix at my disposal, I thought I´d give that a try.
1. For the first shot I just need to cover the globe in realistic looking clouds like those:
Is there a simple way to achieve this with Phoenix?
I was thinking something I could simply add a spherical emitter around the globe and add a cloud-texture to it (like the free ones from nasa) and then use that map as an emitter.
I haven´t used mas to emit smoke yet, but its possible, right?
I have no idea with what kind of settings to start with though...do I emit smoke over time or just with a discharge of one frame?
I´m not sure what kind of scale I´d have to use in that shot, but if I can´t model the earth to scale, I´d just multiply the scene scale.
What else would I have to consider to get only very little or no movement in the clouds at all? Would I have to consider gravity or cooling?
2. From there on I´d like to go crazy and have multiple nukes go off...:
https://youtu.be/hKDXaX07APM?t=1m14s
I´d do some separate sims for those or maybe just do one and then instance the grids with a slight time difference.
So far no big deal.
But for increased impact I´m thinking if it wouldn´t be cool to have the nukes effect the cloud layer...I don´t think they´d have to directy interact with the clouds, I was thinking more of having the reaction be triggered by something else.
The easies way would probably be to just have some spheres or cylinders in the same spot as the mushroom and then scale that up, which will push the clouds aside. But is there a possibility to also kind of dissipate the clouds by that dummy? Can I somehow make it emit heat or something like that? it might all be overkill and I might not even use it, but I´m just curious of the possibilities right now...
So far no big deal.
