Its my 1st attempt and I tried to be close to the concept of the image.
But as you see on the video still needs a lot of corrections.
How can I make the splash more SPLASH! (in the image you have the idea of what I want to achieve)
In the video the corona that is created is too short. And generally speaking the splash is poor compare to the image.
The settings where 1.3 cm grid res. the grid dimensions: 135x102x125
Sub steps: 8
For the Slow motion the time scale went to 0.25 and the sub steps to 2.
The radius of the sphere is 17cm.
Whe I try to resimulate only the foam after a few frames I get the message "Cannot Start the Resimulation - grid dimensions mismatch!"
But I haven't change anything except some options in the foam section. (amount, rise speed etc.)
This happens after about 10-11 frames after the initial collision with the liquid.
Regards,
Zach
Sub steps: 8
Regards,
Zach
