Scripting PhoenixFD
  • Scripting PhoenixFD
    Hi!
    I would like to maxscript the creation of an ocean using PhoenixFD, in particular the Pure Ocean mentioned in the latest build. I cannot find any documentation covering it. Is everything in PhoenixFD scriptable?
    Rune Spaans
    www.superrune.com
    You should be able to change every Phoenix parameter from script - the pure ocean is 'pureocean'. No docs for it yet - we'll update them shortly.
      I found that Phoenix FD is excellent at outputting scripting info to the MacroRecorder. That is rare, well done!! Got an ocean created nicely now.
      One more thing; is there any way to supress the "Use static default geometry" requester that pops up when creating an infinite ocean?
      Rune Spaans
      www.superrune.com
        Ah, yes - I need this too in order to automate some tests. I will add a function or a parameter that would suppress all message po-ups and will update you.
