Hi is there anyway to have room filled with gas and then create an ignition source in the center and then see how fire just travels from the center through out the whole room. We can make explosions local but we want them to expand and travel. For example, fill the tunnel with gas and light one side and then see how fire travels all the way to the other end of the tunnel. is it possible?
And if you have a simple 3ds max example scene where gas ignites and travels through the tunnel that would be great!
Thank you!
Thank you!
