Repeating the same simulation?
  • Repeating the same simulation?
    Hi guys,
    I have a main animation sequence which has a length of 1100 frames and a solved liquid simulation which is exactly 100 frames.
    Now I want the liquid simulation to be repeated 10 times within the main animation (1100 frames). The sim has to start simply
    from the beginning to the end, is paused for some frames and starts again for ten times.
    Any suggestions how to achieve this???
    Best regards, Dirk
    you can loop the simulation from Input roll-out --> Mode set to Loop. Then set the lenght to 100. But I'm not quite sure how to pause it for a couple of frames and then start it again.
      Ah ok, thank you. I will try that,
      Cheers
