Maya - Phoenix Shader Preset
  • Maya - Phoenix Shader Preset
    Does anyway I can copy the same shader from one Phoenixsim to another? It's kind tricky to get a nice realistic fire shader. It took me a while to get what I want so I want to use the same shader for all of my fire.
    Any tip would be helpful. Thanks
    Yup, check saving and loading render presets to a file - this is in the Rendering rollout
      Hi Svetlin,
      I saved rendering preset out as a mel scrip but when i load it in. It giving me error
      // Error: file: C:/Program Files/Autodesk/Maya2017/phoenixfd/scripts/AEPhoenixFDSimulatorTemplate.mel line 1611: No object matches name:
        Ouch, sorry, I missed the Maya part - this is working much friendlier in Max right now. Let me check if I can get this error as well.
          Thanks Svetlin
          Maya just doesn't work well with others =)))....Max seems more stable with Phoenix and Fumefx. Also, Vray work better with Max
            The bug is fixed in the latest nightly build.
            Cheerz!
              Thank you George.
              Cheers,
