Hi We have a truck trailer on fire. Not all of it only where the white part s of noise thats where the fire is (pic attached just an example ). Problem is we are using wetmaps to put out the fire. How can we use wet maps if that map slot is already used by the noise for emission Thank you
Texture emission and wetmaps
A shot in the dark:
Couldn't you mix the maps mith a mix-map or composite-map? Or use the wet-map inverted as white of the noise?Kind regards, Wolf S./K.
www.faber-courtial.de
