Foam not rendering
  • Foam not rendering
    hey guys,
    I?m about to start a new project with some ocean effects, its been a while since my last ocean sims and I wanted to try out the new waveforce.
    It all seems to work fine in the viewport, but I don?t get any foam rendering. Foam appears in the viewport, i can see in the grid info that there should be plenty of foam to render (around 500k right now).
    I remember that there shoudl be a popup before rendering about optimizing stuff, which doesn?t occur.
    I started with the ocean preset and only tweaked a couple of things (adding waveforce and a cutter gizmo), so I?m not sure why I?m not getting any foam.
    I deleted the original foam objects and added a new one, but still nothing.
    I?m on Max 2017 and Phoenix 3.04.01.
    I?ll try to update to the newest nightly and with a fresh scene, but maybe you have an idea what could be the cause of this.
    Ok, starting with a fresh scene seems to have fixed the rendering problem. I?ll get back to you, if I encounter more errors. Well, actually, I?m definitely going to get back at you with more questions, as I add complexity to the sim...
