liquid conservation - reduce
  • liquid conservation - reduce
    I am having an issue where if pure ocean is not checked, I am finding the entire ocean is being flattened out / raised with detail being reduced as a few dolphins exit the water.
    I have attached some images as an example. I would like the liquid to be affected, but in a more realistic manner where the entire ocean level is not affected.
    Hummmm, very weird - does this still happen with a latest nightly? Could you post the settings as well?
      Im using 3.505 stable. I can try the nightly, ive been installing updates to get rid of the flickering issues i posted about a while ago - so I really hope i dont have to update again across the farm so soon. Especially on such a tight deadline.
      All the settings seem pretty standard - what settings should i paste values for??
        Oh, no need to update the farm - you might just install a 3.05.02 nightly locally in order to check if the issue is there - in the shots it seems to be visible in the preview, so it would be just a quick test to verify that it's not already fixed.
        In order to figure out what's going on, would it be possible to either save the settings from Phoenix's Presets rollout, or send the scene over without any geometry - just the simulator. Sorry for the inconvenience!
