PhoenixFD maya 3.10.00 is different result from YouTube tutorial video.
  • PhoenixFD maya 3.10.00 is different result from YouTube tutorial video.
    I translate Basic Liquids QuickStart.
    https://docs.chaosgroup.com/display/...ds++QuickStart
    The scene using Tutorial Assets in PhoenixFD maya 3.10.00 is different result from YouTube video. (Water jumps out of the bottle)
    Where do I fix the same result
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    We're currently looking at it.
    Cheers!
      Hey,
      So the behavior is normal. After a bunch of bugfixes since the tutorial was made, this is how the liquid should behave. You can try a few things:
      - Move the emitter down. Right now it's too far up and the liquid accelerates too much.
      - Make the emitter smaller. Currently it's too large and emits a lot of liquid which splashes hard against the goemetry.
      We will edit the tutorial and the attached scene.
      Cheers!
        thank you for the advice.
        I will write it as a note.
        oakcorp.net
        v-ray.jp
