I can't figure out why the smoke from my sim isn't adjusting the adaptive grid after a certain point. I have the threshold at 0.001 and the extra margin at 10. I attached an image showing the issue and settings.
Smoke not adjusting adaptive grid
Hey,
Here is how to access the Phoenix log: https://docs.chaosgroup.com/display/...ces-Parameters
Cheers!Svetlin Nikolov, Ex Phoenix team lead
Hey,
Here is the simulation we got: https://drive.google.com/open?id=17V...hzTBeatrarwPgI
The adaptive grid is expanding all the time on our machine - does it stop expanding completely for you?
If you get the same results as the video, try increasing the extra margin to like 30-40-50 voxels, so the smoke has more space left to swirl, otherwise the air currents are very limited and even though the wall is open, Phoenix cannot predict how they will behave outside the grid.
In order not to get too large expansion in all the other 5 directions, you can set adaptive limits.
We got the email back from support, and it was creating that "wall" when they tested it. We played around more and found it was only happening when we used the wind force on the smoke. Removing it, or reducing the wind amount seems to stop the smoke "wall" against the grid.
Have you opened a second support ticket? I am looking at 256-404-538.
Yes - I assumed you want the wind in the scene and don't want to remove it, so the extra margin would be the way to allow the smoke to roll better against the grid wall the wind pushes it towards.
