Small scale liquid jumping
  • Small scale liquid jumping
    I am having an issue while simulating a small scale liquid. I simply created a default Phoenix container that is 200x200x30 at 0.002m, set the X, Y, and Z to jammed with initial fill of 50 and hit sim. The liquid gradually becomes more and more chaotic until around frame 100 it is fully jumping around the container wildly. There are no forces, sources, or scene geometry involved in the simulation and it is all default settings.
    Is this an issue with small scale perhaps?
    Phoenix 3.11.00
    Thanks!
    Josh Clos
    FX / 3D Generalist
    Update: I scaled up the simulation 10 times larger; 200x200x30 at 0.02m and now the liquid is mostly calm (however now the scale is incorrect).
    Josh Clos
    FX / 3D Generalist
      Hey,
      Same problem and explanation as this one here: https://forums.chaosgroup.com/forum/...39#post1014539
      Cheers!
        Originally posted by Svetlin.Nikolov View Post
        Hey,
        Cheers!
        Thank you for the quick reply! As suggested in that thread, increasing substeps definitely increases stability for small scales and the explanation makes sense.
        Thanks again!
        Josh Clos
        FX / 3D Generalist
          Cheers man!
