Mist behavior different with cage resolution
  • Mist behavior different with cage resolution
    I have simulated two coean sims with same settings, the only difference being the cage resolution (high 200mio and low 2mio).
    The flying mist is controlled by a plain source and a subtle turbulence. Unfortunally with the high res sim the mist seems to be dying too fast as can be seen in the viewportgrabs I attached.
    I want the mist in the high-res sim to behave like the low-res one (flying consistently away from the crests towards the shore for some time).
    https://wetransfer.com/downloads/42d...2114533/0a223b
    Can you think of a method how to achieve this?
    Maybe increasing life expectancy of the mist somehow does the trick, but how?
    Thanks in advance,
    Chris
    Hey,
    You can check how the Mist particles work in here - https://docs.chaosgroup.com/display/...les+Life+Cycle
    You can play around with the Mist air drag value or add a Plain Force that affects only the Mist particles and push the particles in the desired direction.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Is there a way to simply make mist particles live longer before they dissappear?
        The mist particles are dying based on these conditions :In your case they are entering the liquid so you will need to push them around with the force or change the mist air drag.
        Georgi Zhekov
        Chaos
          Indeed, with a plain force that has only the mist particles in its Affect list, you should be able to blow the particles from the tops of the waves towards the shore. You could angle it so it points up a bit, because right now the mist and splash particles will definitely die in the very moment they touch the liquid surface.
