Network rendering problems - not rendering Phoenix Textures
  • Network rendering problems - not rendering Phoenix Textures
    When rendering via backburner only my workstation (with Phoenix FD installed and FD license) is rendering the Ocean Textures. All render nodes just do not render the ocean (not getting error messages though - just no ocean in the rendered frames...). The path to the Sim in the output settings of the liquid simulator in the scene is a functional network path, so nodes can access sim data (if they have to - I am not sure if this is needed for rendering anyways).
    However, my understanding is that on render nodes only a valid Vray render license needs to be installed, not a Phoenix FD license. (I had asked chaosgroup suppport about this to earlier to clarify).
    Do the PhonixFD textures need to be installed on the render nodes ot render the ocean?
    Hey,
    Yes - you will need to have Phoenix installed on the render nodes as well. There is no need for additional Phoenix license for the nodes, but Phoenix has to be installed in order for the textures to be used.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hi Georgi,
      again: thank you for this quick answer!!!
      Best,
