I'm relatively new to phoenix FD but loving it. However, I have an issue that I just cannot seem to get my head around. I have two liquid sims that I linked in a cascade. although the results are ok, I want to switch around the dependencies. So for example, I currently have sim 2 connected to sim 1 in the cascade. I just want to switch that around. However, it doesn't matter what I do to clear the entry, it always tells me I have a circular reference. I have tried creating a new sim and pointing at it . Then I deleted the new sim and got an entry of none in the cascade slot but still it gives me the circular reference. Any clues anyone ?
Clearing the cascade field
Hey,
If you make a new copy of the simulator and pick it it should be fine, the other option would be to create a brand new simulator (you can use the Simulator presets from the Simulator rollout to transfer your settings, without having to set them manually). Unfortunately there is no way to clear the selection as this is a 3dsmax limitation.
Georgi Zhekov
Phoenix Product Manager
Chaos
