Flickering paused smoke
  • Flickering paused smoke
    I have a segment of an animation that just shows a paused section of smoke (it goes to the end end then stops and holds the frame)
    https://www.dropbox.com/s/e3glrdylgi...x_1_1.mp4?dl=0
    In this segment of video you can see how the smoke holds, flickers, and then holds again.
    At first I thought it might be different machines so I re-rendered all on the same machine,
    It does this regardless of the quality settings I use for GI.
    Can you shed any light on why it might do this?
    http://www.jd3d.co.uk - Vray Mentor
    Shouldn't happen, can you send the scene over?
      Hey,
      By any chance are you using a V-Ray denoiser? Does it reproduce if you turn it off?
      If you increase your Max transparency levels from the V-Ray options does it get better?
      Cheers,
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        It seems as if this is fully about adaptive lights - it doesn't happen with the full light evaluation mode. Do you still want to see the scene or is it not worth it?
          Oh yes, it would be important for the V-Ray guys - if possible,please send it over.
          Cheers!
            I have sent it off to support with reference to this thread.... I hope it helps!
