artefacts when using scattering in Particle shader (point mode)
  • artefacts when using scattering in Particle shader (point mode)
    I had some artefacts in my renders. I finally discovered that these disappear when I disable the scattering in the Particle shader (point mode).
    Phoenix FD 3.14.00 (May 14 2019) / Maya 2018.6 / Build 4.12.02 (V-Ray Next, update 1.1 official) (1 July 2019)
    www.mirage-cg.com
    hmmm, no, still there. It seems to be the LC from render settings. In pure Brute force, no artefact.
    www.mirage-cg.com
      Does it get better if you disable the Light Cache for the Particle shader? If it's still there, can you send over the scene so we can take a look?
      Thanks,
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        I tried to disable the light cache from the particle shader but there is no change. I will send you a scene asap.
        www.mirage-cg.com
          Hi, Other scene, same problem.... but a few more tests. There only way to avoid this square/ straight line is to render BF+BF. In test 3, it's hardly noticeable but it's there. Any idea ?
          www.mirage-cg.com
            Hey,
            Did you send the scene already, because it still hasn't reached us? If you did - can you tell us the ticket number for it?
            Cheers,
            Georgi Zhekov
            Chaos
              Hi Georgi,
              No, I didn't. I will prepare the scene now and send it over with 3 AUR files.
              www.mirage-cg.com
                Awesome, thank you!
                Georgi Zhekov
                Chaos
                  Scene has been transfered. Your ticket number is: 148-136-7314 
                  I tried to send you a PM, but I can't
                  www.mirage-cg.com
                    Thanks a lot for the scene. Looks like it's the Adaptive dome light that causes the trouble. I've logged it as a bug in our system and will update the thread once we have something.
                    If you disable the adaptive dome light it should render correctly.
                    Cheers,
                    Georgi Zhekov
                    Chaos
                      ah, great, I will test that tomorrow ! Thanks a lot !
                      www.mirage-cg.com
