TP and PhoenixFD
  • TP and PhoenixFD
    I'm trying to emit smoke from a group in my TP setup with Polygon ID3.
    They (the group) identify properly with a multi sub material. But Phoenix doesn't seem to identify the source.
    Also it seems like Phoenix needs geo to recognize a particle group from TP. Else the "Group as geometry" simply points Phoenix to the TP_source and uses every particle as emitter.
    Can anyone please share som info on this matter?
    Hey,
    Which version of Phoenix are you using? In the beta builds for Phoenix 4 it should be working correctly as we added a better integration between TP and Phoenix.
    We even have some tutorials on using TP with Phoenix - you can take a look at these two here - https://docs.chaosgroup.com/display/...psing+Building
    https://docs.chaosgroup.com/display/...ardboard+Boxes
    If you're using the Phoenix 4 beta builds and you still have some issues, send over the scene to the support mail and we'll take a look.
    Thanks!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Great! I have the beta but haven't had the time to install. I'll have a look at the links. Much appreciated
