Hi Everyone.
We've got an animated Alembic mesh with changing topology and velocity applied (made in Houdini) for rendering with motion blur in Max+Vray.
Unfortunately when we load the object in a vrayproxy the mesh seems to distort, with the distortion being stronger or weaker depending on the velocity attribute value.
If i load the same alembic file from file-import in max, or if i export the mesh again from Houdini without velocity, there is no distortion, so i guess it's the vrayproxy doing that?
I wonder if there is anything wrong i'm doing or if it's a known issue.
p.s. Normal particles seem to work perfectly fine with no "distortion" on their position.
