Why is my fluid just stopping in mid air... baffled
  • Why is my fluid just stopping in mid air... baffled
    I am completely stumped by this. I am trying to do a waterfall and per the image my fluid just seems to get stuck and doesn't go past that point. The spray and mist and the like are there but the fluid gets to that point and sort of flickers.. the mesh grows a bit more than what you can seen but then some parts just disappear, and the actual fluid never gets to even close the the bottom of the drop.. I am completely stumped as to why this is happening.
    I used the water fall preset as the basis for this.
    there is an option to transform the free faling liquid into splash, see the splash birth conditions https://docs.chaosgroup.com/display/...plash+%7C+Mist
    VRScans developer
      Hey,
      Take a look at the Affect Liquid option, when this is above 0 the splash birth causes some of the liquid to disappear, and then when the splash enters the liquid the splash particles are replaced by liquid.
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        And let me drop in on this as well Here's the life cycle of the FLIP particles, showing which particle converts into what: https://docs.chaosgroup.com/display/...les+Life+Cycle
          peeeeeeerfect.. I am back to it
          Thanks for the settings tips and the life cycle - that is an interesting read.
