openVDB in VolumeGrid: When "LOD" + "number" is in the name, then it does not load
  • openVDB in VolumeGrid: When "LOD" + "number" is in the name, then it does not load
    Hello,
    I have clouds for testing with different LOD.
    they are named "...LOD0", "...LOD1", ."..LOD2" and at the end of course ".vdb"
    But as long als there is "LOD" and a number in the name, the openVDB does not display in the viewport.
    When I delete LOD from teh name, they work
    Is there a hidden setting?
    They are automatically displayed as "...LOD#..." in the input.
    Thanks
    Hey, sounds like you just gotta rename them manually in the input - just edit the text field with the path and put the hash sings where they need to represent timeline frames, or just temove them altogether if your clouds are single frames only.
    Cheers!
