I found out, that a Gradient Ramp seems to have no effect, if I use it as Alpha for Volume Brush.
I wanted to animate a stripe. When I disconnect the map again everything emits....
(I double checked with a checker board, which is working as alpha)
If there is another node to create a thin alpha stripe, let me know. thanks...
2.)
I tried to achieve the same with a Discharge Modifier
- on the one hand I would need an orientation diagonally in space.
I used "Object Z" as Position and rotated the Objects gizmo.
Unfortunately the Object space is the same like world space, the rotation had no effect.
- and it seemed impossible to animate the curve of the Discharge modifier (I tried Auto-key)
As always happy for any suggestion
2.)
