Looping ocean waves
  • Looping ocean waves
    I folks I know this has been asked before but the posts are pretty old and was hoping this feature is now available.
    I have just downloaded PheonixFD demo for a very steep learning curve to see if we can use it for a current project with Autodesk!
    We need to loop a calm ocean water sim over 5 sec
    Is this possible?
    Thanks for any help.
    Hey,
    Yes, you can loop an Ocean texture now: https://docs.chaosgroup.com/display/...meBendControls
    Cheers!
      Thank you very much, cant believe it was that easy, I was dreading having to solve this issue. I have managed to connect the PheonixFDOceanTexture onto a poly plane and got it to loop.
      Awesome!
      Full purchase on the way..
        yep, it works very well. I used it several times.
        www.mirage-cg.com
          OK first issue.
          We have a camera override on when rendering in VRay to add some padding but on rendering the ocean, it appears to blur in these areas.
          How do I correct this effect?
          Thanks
            You will need to tweak the Off-Screen margin value - https://docs.chaosgroup.com/display/...endering-Ocean
            Georgi Zhekov
            Phoenix Product Manager
            Chaos
