Installation issue with v-ray 5 and viewport doesn't show simulation
  • Installation issue with v-ray 5 and viewport doesn't show simulation
    Hi!
    When I installing Phoenix FD 4.30 for 3ds Max 2021.3 with v-ray 5 hotfix 2, in the bottom appears a message saying that v-ray 5 instalation was not found. I clicked continue and everything went apparently fine (the exception being that in the V-ray GPU additional files the field being empty).
    Opening 3ds Max and trying to simulate fire, nothing shows up in viewport. However, when rendering everything goes fine.
    What can I do to solve this?
    Hardware: laptop, i7 generation, 32GB RAM, Nvidia GTX 1050
    Hey,
    Is there any chance you installed V-Ray 5 somewhere other than the default location?
    Would it be possible to send the Phoenix log from C:\PhoenixFD after you load 3ds Max, simulate and render?
    Cheers!
      Originally posted by Svetlin.Nikolov View Post
      Hey,
      Cheers!
      Thanks for the swift answer!
      No, V-Ray 5 was installed in the default location.
      I uploaded the log from a simulation made a few minutes ago.
        Hmm, everything looks fine. I suspect that something might have went wrong with the Windows registry preventing the V-Ray GPU/standalone plugin to be installed. Can you try reinstalling V-Ray 5 and the Phoenix FD again?
        I also suspect the viewport issue is unrelated - the same dll that does the simulation also does the viewport preview. Can you show me how the viewport looks and screenshots of all the Simulator's rollouts?
