Hello everybody,
i know i posted this Question already a long Time ago
i always struggle with the same Foam Issue/Problem... when i use the Variation Large Amount int the Foam i got those Foam Bubbles leaving the Mesh with to much Speed. Even if i use the Half Life "Vary" Button. You can trust me i tried so many Variations of Rising Speeds, Sizes, B2B interactions and SPF. My Goal is to achieve a Foam Volume with much different Sizes as you can see in the Image. I would like to see those "Black Holes" do you see what i mean? The Rising for the Average and small sized Bubbles must be enough to form those nice Foam Patterns on the Surface of the Water Body. In my Opinion it would be great to have more Control for the Foam. Something like biggest Bubbles stuck to every other Bubble. Another Thing i already tried could possibly the Solution. More SPF, but this takes all Turbulence out of the Sim, yes it is more stable but boring. Maybe someone can help. Thanks in Advance.
Kind Regards David
Kind Regards David
