Hi all,
I've had this catch me out a few times with several files recently, will double check settings to make sure I'm not doing something stupid or see if I can track down any more info.
If I have V-Ray GPU Next selected as the renderer and queue a Phoenix FD sim via the Submit Simulation to Backburner menu, the job submits ok and is picked up by a render server but doesn't start processing frames and hangs at 'Starting GPU engine...'.
If I set the renderer to V-Ray Next and submit the sim, it processes as expected. FWIW the same scenes render fine with GPU Next, once the sim has been cached.
Max 2018
V-Ray Next update 3.1
Phoenix FD 3.14 Build ID: 20190427
Backburner 2018.0.0.3005
Thanks for any help!
Jon
Max 2018
Jon
