Maya Playblast not showing OceanMesh
  • Maya Playblast not showing OceanMesh
    Hi, I'm working on an ocean simulation with a ship. For testing the scene I wanted to create a playblast of the animation. But the only visible element in the final avi or qt file, is the ship. The ocean mesh is not visible. Is it a Maya issue? Can't find anything on the net.
    Playblastsettings are standard
    regards t.
    Hey,
    Do you have the Hypershade window open while creating the Playblast?
    Could you try creating a Playblast with the Hypershade closed, because there seems to be a problem when it's open during the playblast process.
    Thank you!
    Slavina Nikolova
    Phoenix QA Specialist
    Chaos
      Hey Slavina, exactly! Thank you! The Hypershade was the issue! Problem solved.
      Kind regards T.
