need help on this simulation *URGENTE*
  • need help on this simulation *URGENTE*
    HI, I am having a big problem here; take a look at this video. https://www.youtube.com/watch?v=9pmXxT2Bv-8
    Can I send these scene to support so you can help me out what is going on with my setup? I am hitting solid walls and cant find any solution to this.
    Surrealismo
    https://www.facebook.com/surrrealismo
    Hey,
    Yes, please send over the scene to the support mail along with a link to this thread and we will take a look.
    Thanks!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hey, just to make sure we are on the same page - are you talking about this box showing up?
      If yes, can you explain your setup?
      I also assume you are using a very latest V-Ray and Phoenix so we are not chasing problems which have already been solved?
      And finally, can you attach your Phoenix log from right after rendering has completed (it's in C:\PhoenixFD). It might contain warnings or errors.
      Thanks!
        yes, but another two errors. (attached images).
        unfortunately, I am on vray next 4.30.3 and phooenix 3.14.01.
        Surrealismo
          scene sent to support! thank you for your help!
          Surrealismo
            We got the scene, thanks! Will let you know when we have something!
            Georgi Zhekov
            Chaos
              Hey,
              Couldn't get the black artifacts here, but noticed that the surface level of the liquid is a bit mismatched. You have a few simulators that are merging into one ocean, but those simulators are in different positions on the Z-axis.
              In order to get consistent and good results make sure that there are no overlapping simulators and they are on the same level. In your scene I moved the PhoenixFDLiquid_Chorritos_002 simulator to be on the same position on the Z-axis as the master ocean simulator PhoenixFD_Palmera1_004 and then set the Ocean level to 8 as 7 was a bit too low. You can find more about the Ocean settings here - https://docs.chaosgroup.com/display/...endering-Ocean
              Hope this helps!
              Cheers!
              Georgi Zhekov
              Chaos
                hi georgi, I thought that the ocean level has to be really close to the percentage of the initial fill up. How can I determine the number I have to put there¿
                Surrealismo
                  It's best to start with the same number as the initial fill up and then adjust it a bit up or down if needed. Unfortunately for now there is no better way to do it.
                  Georgi Zhekov
                  Chaos
                    Got better the result but still the weird shadow on the left. take a look at the video. https://www.youtube.com/watch?v=b00A5NRdOoo
                    Does this has to do with the ocean offset?
                    Surrealismo
                      Ah, try increasing the ocean off screen margin option a little.
