Good evening,
I'm testing out a "Small scene" to introduce myself to animations.
I was choosing between corona and vray, starting at first with corona and finally deciding to vray for more compatibility with software and plugins.
Simulation is exactly the same, I only converted shaders and lights.
I set up the wetmap to last 5 secs, but seems that with vray is not recognising it(tested with a very very low res quality animation).
Also, in corona the wetmap sees some more particles splashing around.
Then, other problem I found, is with renderfars, either chaoscloud or pixel plow.
When I rendered a test, seemed the wetmap wasn't recognized at all, so it was like to have just a single material rather than the mixed one.
Is there any reason about this?
If needed I can share the scene, even if it was shared previously with the support, but for other reason.
Thanks in advance,
Lorenzo
Thanks in advance,
Lorenzo
