Maya 2022: Error with OnSimulationEnd script
  • Maya 2022: Error with OnSimulationEnd script
    I used a script with Maya 2020.4 and Phoenix 4.40 to render the simulation automatically when it stops. However, with Maya 2022.1 and Phoenix 4.41, I receive the following error:
    // Error: Error importing renderOnSimEnd python module - (kFailure): Unexpected Internal Failure //
    Code:
    //renderOnSimEnd.py
    import maya.cmds as cmds
    def OnSimulationEnd(node, t, dt):
    cmds.vrend()
    I realize Maya 2022 runs with Python 3, though I'm not well versed in the differences between Python 2 and 3 if that is the issue. Any suggestions would be appreciated.
    Hey,
    We had some Python fixes before a couple of weeks, so this might be the problem. Could you try with latest Phoenix Nightly - https://nightlies.chaosgroup.com/mai...est/2021-10-11
    Here you can find more information about the scripting - https://docs.chaosgroup.com/display/PHX4MAYA/Scripting
    Hope this helps!
    Slavina Nikolova
    QA Specialist, V-Ray for SketchUp | V-Ray for Rhino | Phoenix
    Chaos
      The latest nightly build did the trick. Thanks!
