Hey everyone,
I'm relatively new to phoenix and coming across a consistent issue that I'm hoping there's an easy solution. When I go to iterate a simulation, specifically adjust the emitters due to client feedback when I press the 'start' button it goes through the process of simulating, writes cache files, etc. However looking at the 'Cache File Content' panel there are 0 particles being created. Reviewing the simulation and cache file size there are definitely no particles being cached.
This happens during the following procedures:
What I've done to troubleshoot:
Making this clear, no errors are thrown, it looks like it's working properly, however 0 particles are being generated. This is a simple paint dripping animation without any unique or complicated effects/settings or modifiers used, pretty much 'vanilla' simulator settings.
My setup is 3dsMax 2017, Vray 5.1003 and Phoenix 4.3000
Thank you for any help you can offer.
Sean
- Adjusting the size of the emitters
- Changing the cache to iterate simulations and start a new cache
- adding emitters to the liquid source
- removing emitters from the liquid source
- adding an additional liquid source
- Uninstall and reinstall VRay and Phoenix - Doesn't seem to be install related
- Delete everything out of the scene and create a new liquid sim with a sphere (still no particle generation) - Proves it's not my particular simulator nor bad settings in my simulator
- Open a new scene (without reloading Max) simulation works perfectly. - Looks like it doesn't dump needed files mid 3dsmax session.
Sean
