Foam is dropping below water surface outside of sim
  • Foam is dropping below water surface outside of sim
    ​Attached image shows where the foam drops below the surface of the water...there is a distinct colour change right where the sim stops. Can this be resolved? I'm a bit of a noob with phoenixfd and oceans.
    Regards
    Steve
    My Portfolio
    you could try to render only the foam (hiding the sea) to see if issue is still there. Also, you could try to disable the displacement of sea to see what happens.
    www.mirage-cg.com
      Also, try the Vertical Offset option in the Particle Shader.
        So, this is what it looks like with no refraction and no displacement. There is a very obvious cut where the sim ends. The foam actually continues much further than where I've drawn the line indicating the sim end.
        Wouldn't affecting the vertical offset change all the foam meaning some one be floating above the ocean?
        is this a limitation of Phoenix?
        Regards
        Steve
        My Portfolio
          So I've had to adjust the vertical offset to 0.24m. Now the foam outside the sim is visible but now I have foam sitting 0.24m above the ocean in the sim area.
          Regards
          Steve
          My Portfolio
            Yes, if the foam outside the simulator matches the foam inside it, it would be just by chance. Note that outside the simulator many of the fluid solver processes do not happen - they can't because this area is not simulated. So foam would rise to the ocean fillup level, but this might not be the level that the liquid actually reaches during simulation, so it might still be below the Ocean Level % option. The only way to make completely sure that foam would not end up under the liquid surface when it exists the simulator, is to make the simulator long enough so the foam does not exit it. If you are worried about increasing the grid resolution, try a more shallow simulator.
              Thanks. I thought that might be the case with having to extend the simulator. Okay, thanks for the info
              Regards
              Steve
              My Portfolio
                I should be able to rework the Vertical Offset to affect only the outside of the selected Liquid Simulator in the particle shader - this might be a solution for such problems but I hope it won't make the foam move in a fake-looking way....
                  I guess maybe instead of a sudden vertical offset for items outside the sim you could have a parameter to gradually increase the offset over a distance that can encroach on the sim itself?
                  Regards
                  Steve
                  My Portfolio
                    Oh yes, it has to gradually change but since this would be an effect of the simulation's foam rising speed, it might not always look well... Will think about it more.
                      Hey, so in Tuesday's nightlies there will be a hidden script option the particle shader which can change the behavior of the vertical offset.
                      You gotta select the Particle Shader and in the maxscript listener type:
                      $.vertoffscond = 0 - this is the default behavior of the Vertical Offset
                      $.vertoffscond = 1 - a new method that offsets only the particles outside the linked Liquid Simulator with some falloff near the simulator edges.
                      $.vertoffscond = 2 - another new method that offsets only the particles outside the linked Liquid Simulator and also squashes them forcefully to the Ocean Level of the Liquid Simulator, before applying the vertical offset. Using this, there can't be any flying particles in the air outside the simulator - all particles will be forced to the ocean level and if they are below or above, you can adjust this using the vertical offset option.
                      Both methods are not perfect and I got some mixed results - you can get the particles inside the simulator looking like the particles outside it, but right at the border there might be a visible particle streak.
                      Please, if possible, check these two methods with your scene, also adjusting the vertical offset and ping me with the results - if any of the two is working fine, I will expose it in the GUI for Phoenix for Max and Maya, otherwise I will go back to the drawing board
                      Cheers!
                        Hey, just checking if you've had the opportunity to try this out?
                          Hey there. That's amazing work. I've yet to try it out because I'm working on a live project currently. I'll give it a go once I get the chance
                          Regards
                          Steve
                          My Portfolio
                            Hooray!
