Foam point mode issue
  • Foam point mode issue
    I have an issue I don't seem to have experienced before.
    When I render the foam particles in point mode, I have some strange dark/black areas coming up. It seems to happen in areas where there is a high density of particles, and it doesn't occur when I render the foam in bubbles or cellular.
    Foam points
    Foam bubbles
    Foam cellular
    Foam points zoomed
    And when you zoom in, the issue seems to disappear. I don't think I ever experienced such a problem with previous versions of Vray/Phoenix
    Maya 2019.3.1, Vray V6.00.02, PhoenixFD 5.01.00
    I tried, in the phoenix shader, to play with Motion Blur, Scattering, Volume Light cache, size addend, vertical offset. Nothing helps. The only thing is that when I reduce the count multiplier, it seems to damp the issue.
    I'm still testing.
    www.mirage-cg.com
    oh, and it's not that the particles are killed or dissapear. As you can see in the alpha, there are particles, but they are dark.
    www.mirage-cg.com
      ok, something is broken or definitely different with shadow strength.
      Without shadow strength, the problem is gone, but it looks like S[censored]t
      www.mirage-cg.com
        Oh, huh, could you send this file along with one cache so we can see what's up? This doesn't look right at all.
          Thanks, I will try to put something together and send it to support.
          www.mirage-cg.com
            Hi Svetlin,
            I sent a stripped down project to the support (Your ticket number is: 65065)
            There is an AUR on frame 500 which is the one I tested.
            I'm curious to see what you can find.
            cheers
            www.mirage-cg.com
              Sweet, got it! Thank you! We will ping you when we know more...
                great !
                If it can help: I was also trying out to export particle RGB on this simulation. In the Phoenix particle shader, it is not used, because I couldn't find any good way to use it. But maybe it has something to do with it.
                www.mirage-cg.com
                  Ah, okay, we'll see! We managed to reproduce the problem here and now Slavina is simplifying it...
                    great, thanks a lot!
                    www.mirage-cg.com
                      Hey,
                      While we're checking the scene, you can try the following steps as a workaround:
                      - set the Scattering to Approximate+Shadows;
                      - keep the Volume Light Cache enabled;
                      - decrease the Point Radius (I tried with 1.5);
                      - decrease the Shadow Strength (I tried with 0.6).
                      Hope this helps!
                      Slavina Nikolova
                      QA Specialist, V-Ray for SketchUp | V-Ray for Rhino | Phoenix
                      Chaos
                        Originally posted by slavina.nikolova View Post
                        Hey,
                        Hope this helps!
                        Thank you Slavina. That seems to do the job for now!
                        www.mirage-cg.com
                          Except that with Scattering the foam becomes very bright. That's why I don't use it anymore. We could need a scattering multiplicator
                          www.mirage-cg.com
                            Any news on this issue ?
                            best,
                            Olivier
                            www.mirage-cg.com
                            • #15
                              No, will try to have a look at it next week...
                              Cheers!
