White spots in smoke.
  • White spots in smoke.
    Hi All, -Thank you for any tips, help, time, -I sincerely appreciate it !
    I'm getting white spots in the smoke when I render (3ds Max 2023, Vray6 Hotfix 3 6.00.20, PhoenixFD 5.01.00 ).
    This VFX setup was from the Flamethrower tut: https://docs.chaos.com/display/PHX4MAX/Flamethrower <--outstanding and Thank You!!
    Vid;
    https://www.youtube.com/watch?v=PN5whFY1g6A
Name:	Screenshot 2022-11-21 145003.png
    I'm guessing it's a very basic setting that I'm missing?
    When rendering with an HDRI dome light, or in an all black background scene, the default final scene downloaded from the tutorial, -the white spot artifact doesn't show up.
    Currently it's showing up when I attempt to render the scene with a background plate, background is animated png sequence. .
    For the PhoenixFDFire, it has just a dome light on it (see the last image, VrayLight006), -using an EXR HDRI for the dome light, Vray shadow catcher on Vray plane, background is an animated png sequence.
    I've tried to fit more of the scene settings on these images;
Name:	render settings.jpg
Name:	scene setup shot.png
    If needed, glad to upload the scene file, or include any additional info that might help.
    Thanks again!
    Oh, how about it you lower the Volume Light Cache Speedup in the Smoke Color rollout? Or even if you do a test with the Volume Light Cache turned off?
      Thank You Svetlin ! Will do!
        Outstanding, you're brilliant, -that fixed it ! Thank You! Thank You! Thank You!
        (a little zoomed in);
Name:	Screenshot 2022-11-22 095151.png
        p.s. Since I've got it posted, I welcome anyone's feedback on this too. Feel free to RIP on it, anything that could be improved, etc. (no offense will be taken in anyway, and I appreciate the time / feedback on it !)
        Thanks again!! All the best!
