Restore a Sim from Command Line
  • Restore a Sim from Command Line
    I am using the PhoenixFDSimulate.ms script to run sims manually form the command line (with no gui).
    I am now trying to do a Restore operation from a particular frame. So I modified that script to start the sim like this:
    Code:
    A_StartSim(PhoenixFDObjectsToSim[i],"G:/MyPath/MAX/sceneassets/PHX/MySim_0930.aur",930)
    I tried backslashes. I tried escaped (double) backslashes. All of this causes an Error Executing Script, and highlights this line of code, but give no additional info.
    How can I start a Restore operation form the command line, restoring from a particular frame?
    Thanks.
    Based on docs here: https://docs.chaos.com/display/PHX4MAX/MaxScript#MaxScript-StartSim
    Oh, duh, It's my lack of familiarity with MaxScript function calling syntax... It's not like C (which everything should be).
    Code:
    A_StartSim(PhoenixFDObjectsToSim[i]) "G:/MyPath/MAX/sceneassets/PHX/MySim_0930.aur" 930
      Ah yes, I believe even the first pair of braces could also go
        Yeah, I figured, but since they were in the original it threw me.
        I still thing all languages should have the basic syntax of C
        thanks.
