I get this in my Deadline log. The same scene sims fine with Max mode.
This is also why I was asking in another thread if the standalone window (cmd.exe) could stay open if there was an error, because the local standalone sim failed too, but I couldn't read the error (or find the log file if there is one).
I assume the warning comes from the fact that I have a 3d text object that has a push modifier on it that causes some self intersecting geometry. Could that junk geometry also cause the error listed?
Is the ERROR:
actually fatal? Deadline thinks it is and ends the job.
Thanks.
Is the ERROR:
Code:
[ERROR] SimBodyGeomStnd::build no geometry
Thanks.
Code:
2023-04-12 18:11:32: 0: INFO: Executable: "C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2023 for x64\bin\phoenixfd.exe" 2023-04-12 18:11:32: 0: INFO: Argument: -scenefile=C:\ProgramData\Thinkbox\Deadline10\worke rs\vole\jobsData\6435c03a8b86c61574a06e38\IceType7 5.simscene 2023-04-12 18:11:32: 0: INFO: Full Command: "C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2023 for x64\bin\phoenixfd.exe" -scenefile=C:\ProgramData\Thinkbox\Deadline10\worke rs\vole\jobsData\6435c03a8b86c61574a06e38\IceType7 5.simscene 2023-04-12 18:11:32: 0: INFO: Startup Directory: "C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2023 for x64\bin" 2023-04-12 18:11:32: 0: INFO: Process Priority: BelowNormal 2023-04-12 18:11:32: 0: INFO: Process Affinity: default 2023-04-12 18:11:32: 0: INFO: Process is now running 2023-04-12 18:11:36: Listener Thread - ::ffff:192.168.0.222 has connected Success 2023-04-12 18:11:44: 0: STDOUT: Simulating scene "C:\ProgramData\Thinkbox\Deadline10\workers\vole\j obsData\6435c03a8b86c61574a06e38\IceType75.simscen e": 2023-04-12 18:11:44: 0: STDOUT: Chaos Phoenix 5 ADV for 3ds Max 2023, 2023-04-12 18:11:44: 0: STDOUT: version 5.10.01 Nightly, Build ID: 2023012631862 from Jan 26 2023 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:32] Loaded C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2023 for x64\bin\distance_measurer_phx.dll 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:32] All simulation plugins loaded successfully from C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2023 for x64/bin/plugins 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:32] Grid set to 239 x 91 x 242, 792933184 voxels, memory usage 53.170GB 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:32] Sim started 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:32] The simulation cache files will be written to G:\MyProj\Max\scenes\Type.max_Phoenix_frames\PhoenixFDFire001B_####.aur. 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:32] Sim step 0, sim time:0.000000, last frame:0.000000, elapsed: 0.000000 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:33] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:44: 0: WARNING: [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:33] [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: D2@node_2 2023-04-12 18:11:44: 0: STDOUT: E@node_12 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:34] export frame 125 fill: 0.129292 <----------------------------- FRAME: 1/201 (0.50%) 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:34] 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:34] Sim step 1, sim time:0.041667, last frame:1.451604, elapsed: 1.784574 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:34] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:44: 0: WARNING: [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:34] [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: D2@node_2 2023-04-12 18:11:44: 0: STDOUT: E@node_12 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:35] export frame 126 fill: 0.152611 <----------------------------- FRAME: 2/201 (1.00%) 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:35] 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:35] Sim step 2, sim time:0.083333, last frame:1.563424, elapsed: 3.295844 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:36] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:44: 0: WARNING: [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:36] [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: D2@node_2 2023-04-12 18:11:44: 0: STDOUT: E@node_12 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:37] export frame 127 fill: 0.165371 <----------------------------- FRAME: 3/201 (1.49%) 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:37] 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:37] Sim step 3, sim time:0.125000, last frame:1.542462, elapsed: 4.866405 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:37] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:44: 0: WARNING: [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:37] [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: D2@node_2 2023-04-12 18:11:44: 0: STDOUT: E@node_12 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:38] export frame 128 fill: 0.177659 <----------------------------- FRAME: 4/201 (1.99%) 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:39] 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:39] Sim step 4, sim time:0.166667, last frame:1.623629, elapsed: 6.517213 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:39] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:44: 0: WARNING: [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:39] [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: D2@node_2 2023-04-12 18:11:44: 0: STDOUT: E@node_12 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:40] export frame 129 fill: 0.193753 <----------------------------- FRAME: 5/201 (2.49%) 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:40] 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:40] Sim step 5, sim time:0.208333, last frame:1.664668, elapsed: 8.237806 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:41] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:44: 0: WARNING: [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:41] [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: D2@node_2 2023-04-12 18:11:44: 0: STDOUT: E@node_12 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:42] export frame 130 fill: 0.203557 <----------------------------- FRAME: 6/201 (2.99%) 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:42] 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:42] Sim step 6, sim time:0.250000, last frame:1.759395, elapsed: 10.001770 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:42] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:44: 0: WARNING: [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:42] [WARNING] The following objects are not closed meshes! This may cause unexpected simulation results: 2023-04-12 18:11:44: 0: STDOUT: D2@node_2 2023-04-12 18:11:44: 0: STDOUT: E@node_12 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:44] export frame 131 fill: 0.216280 <----------------------------- FRAME: 7/201 (3.48%) 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:44] 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:44] Sim step 7, sim time:0.291667, last frame:1.774894, elapsed: 11.833994 2023-04-12 18:11:44: 0: STDOUT: [2023/Apr/12|18:11:44] [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:45: 0: Done executing plugin command of type 'Render Task' 2023-04-12 18:11:45: ERROR: 0: An exception occurred: Detected an error: [ERROR] SimBodyGeomStnd::build no geometry 2023-04-12 18:11:45: at Deadline.Plugins.PluginWrapper.RenderTasks(Task task, String& outMessage, AbortLevel& abortLevel) (Deadline.Plugins.RenderPluginException) 2023-04-12 18:11:45: 0: Unloading plugin: Phoenix 2023-04-12 18:11:45: 0: Executing plugin command of type 'End Job' 2023-04-12 18:11:45: 0: Done executing plugin command of type 'End Job' 2023-04-12 18:11:48: 0: Render Thread - Render State transition from = 'Rendering' to = 'WaitingForTask'
