Cloud Sim not rendering with Arnold Volume
  • Cloud Sim not rendering with Arnold Volume
    Hello,
    I am ruing the Phoenix time laps cloud sim example and when i save it as a VDB and load it into a Arnold Volume it doesnt render. Regular Phoenix smoke sims render fine but the time laps cloud sim does not. Is there something different in the setup from a regular smoke sim? Here are the my steps:
    attached phoenix cloud sim to cube
    save sim cache as openVDB
    run sim
    create arnold volume and plug openVDB cache as sequence and for grids select the 3 velocity grids and 1 smoke grid
    for velocity grids select 3 velocity grids
    attache aiVolumeShader to arnold volume
    add a light
    render and then stare into the cold darkness of space
    below are my settings
Name:	Screenshot 2023-04-16 141711.png
ID:	1178169 Click image for larger version
Name:	Screenshot 2023-04-16 141711a.png
    Hey, sorry for the late reply.
    There should be no difference between this setup and a regular smoke setup. Could you compare the Cache File Content box in the Simulation rollout when you have loaded one VDB or the other? (You could alternatively just double click each VDB and compare this info in the Phoenix Previewer, without having to open Maya at all)
    Cheers!
      I figured it out. I needed more light. 15 intensity wasnt enough which is unusual. needed 30 to see it. thanks again.
        Ah, whew, thank you for getting back to me!
