sphere fade and glass material
  • sphere fade and glass material
    Hi everyone!
    I have an issue with VRaySphereFade effect in combination with Glass material.
    First, i did a serch on chaosforum but i did not found an answer.
    i have VRay 5, update 2.3
    please check the attachment (a simplified structure that presents the facts of the case) corresponding with the following text:
    1. VRaySphereFade effect attached to a...
    2. SphereGizmo
    3. The scene contains a ground plane, a window with a std glass material
    4. Issue: in the final render you wont see the "empty color" and the fade from the SphereFade settings
    thanks
    chris
    Hi chris_jungle,
    Does this happen locally when rendering with V-Ray in 3ds Max? It seems to me this inquiry is for the V-Ray for 3ds Max forum.
    Thanks,
    Vladie
    Vladimir Dragoev
    Product Specialist
    Chaos Cloud
      Hi Vladie
      Sorry for the late reply! It happens locally, i took the wrong forum for this question.
      Are you able to move my post?
      Thank you!
      Chris
        Yep. I will move it now. Thanks!
        Vladimir Dragoev
        Product Specialist
        Chaos Cloud
