Hello friends,
I'm sure someone can point me to the right solution with this issue.
My shadow renders fine when above objects or VRAY plane, but in After Effects it is not visible above the environment alpha:
When I but the AO pass beneath the RGB pass, I can see the smoke properly but a thin white line appears on the edges between alpha and RGB:
Inside Chaos Player it looks great, so I wonder - how can I extract that info without re-rendering the whole sequence?
For reference, these are my Volumetric Render Settings for that smoke:
Thanks in advance!
Barak Vinner
Thanks in advance!
Barak Vinner
