A file rendering fine locally isn't working on net render. I'm using Cache Index and the single cache file is referenced directly through the network in the Input tab. I changed the name of the local cache folder to check I wasn't accidentally referencing that. no problems there - the local render is also referencing the file on the network. One thing, the cache file is a resim file, but that shouldn't make any difference right? The file is large (about 1.7GB). Could that be causing the issue?
trouble with net render
