Ocean render
  • Ocean render
    Is there any way to render just the boat and its wake? without the water!!!
    I need to upload the rendering of the boat and just the wake and merge with the ocean from a stock image. Is there any channel to do this?Click image for larger version
    Hey,
    Sure you can do that, select the simulator right-click and from the Object properties menu disable the "Renderable" checkbox.
    This will make the ocean mesh not renderable while everything else should remain the same.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
