Rendering animation error Embree static ray caster
  • Rendering animation error Embree static ray caster
    Hi
    I am trying to render an animation with a phoenixfd simulation using V-Ray 6 Update 1.2
    The rendering stops after the first frame with the following error in the Vray log window:
    Error : Error building Embree static ray caster, error message: [CommitEmbreeThread::threadProc] 1: Setting progress monitor function failed
    Any idea what is causing this error?
    It looks like the render engine is not able to mesh/compile the phoenix sim files on time in 'mesh mode'?
    By changing the rendermode in the Phoenix rendering tab to Isosurface (V-Ray) does get rid of the error but this mode renders really slow.
      Hey,
      Does it happen with any scene or just a specific one?
      If it happens only with a specific scene - can you send the scene over through the support form here (there is Submit a request button in the top right) - https://support.chaos.com/hc/en-us
      Thanks!
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
