Good morning, I have this error all the time, as soon as I open 3dsmax, the first warning appears (image 1) and a few minutes later while I'm working, the second warning.(immagine 2) The second warning appears continuously, it is not possible to work.
Win 11 - 3dsmax 2024.2 - Vray 6.10.20 build 32289 - phoenixFD 52002_max2024_vray6_x64_32293 . Can you help me? Thanks for help!
- install the latest Phoenix nightly
- open 3ds Max
- open the Editor Window
- close the opened file - right mouse click over the name and select Close - don't save the changes
- reopen 3ds Max
Thanks!
Slavina Nikolova QA Specialist, V-Ray for SketchUp | V-Ray for Rhino | Phoenix Chaos
Could you share your exact steps, so we can try to reproduce it here?
Also, does it reproduce with a specific scene? If so, could you share a simplified scene that we can check?
One more question - did you close the opened script file from the Script Editor Window? The window should look like my screenshot, if the script is closed.
