Fireflies when rendering with vray
  • Fireflies when rendering with vray
    I thought this was fixed with adaptive lights?
    Phoenix fire renders a lot of fireflies.
    Setting the fire to "fully visible" in fire opacity helps a bit.
    Turning off "visible in reflections" in vray properties solves it, but no reflections...
    Any help?
    Hey,
    Can you show us how it looks - which v-ray version are you using?
    Is it possible to send us a scene so that we can take a look?
    Thanks!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Vray: 6.20.02
      Visible to reflections ON
      Visible to reflections OFF
      Attached scene
        Any insights? Am I doing something wrong?
          I looked at your scene yesterday and I reproduced the problem. Most likely it comes from overbright flames that are being reflected by the glossy surface.
          All I can say for now is that the noise threshold is too high.
          https://drive.google.com/file/d/1WYu...ew?usp=sharing
          I need to dig a bit more to try to find what it is exactly and how to work around that. And how to make the scene render correctly with your specific curve.
            Thanks a lot - I'll try the changes in the vid
