Can't Drag Simulator Properties to the Main Window
  • Can't Drag Simulator Properties to the Main Window
    Is there some trick to dragging the properties to the "Main Window?" I just get the red no-no symbol when I try to drag one of the rollouts from the simulator over to it.
    Thanks.
    No, there's no trick. You can double-check if the max UI is unlocked. (It has to be). Also, I assume you are talking about MAX. If so, which version?
    The red no-no symbol that you are describing is something that I've never seen.
    Do you have a multi-monitor setup? Are the monitors using different scale? Can you please give us some more info or a screenshot, perhaps?
    Thanks
