Hello!
I encountered a strange error in the alpha element and this wasn't the first time. When using particle shader in point mode, you may experience some unusual results as the attached screenshot shows. I've tried multiple setting in Vray render settings but its clearly related to the pixel size in particle shader. Did anyone find a cure for this issue?
