Rocket Exhaust Issue
  • Rocket Exhaust Issue
    I'm getting some issues with a rocket exhaust sim. Not sure if it's a bug or I have a setting wrong.
    I'm attaching the Maya scene.
    I'm using Maya 2024.2, Vray 6.20.02, Phoenix 5.22
    https://drive.google.com/file/d/1klx...ew?usp=sharing
    Hey,
    Sorry for the late reply.
    I tweaked a few settings here and got something like this.
    1 - The particles were moving quite fast and the simulation couldn't keep up. I slowed them down a lot and increased the steps per frame to 2.
    2 - The scene scale was a bit small so I increased it 5 times.
    3 - The Phoenix Source was emitting way too much fire and smoke - I dialed down the discharge to 5.
    4 - In the Phoenix Source I changed the Particle Shape to be set to use a Sphere with a custom size of 2. You can find more about particle emission here - https://docs.chaos.com/display/PHX4M...nfromParticles
    Hope this helps!
    ​​ Click image for larger version
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Georgi. Is the reason for increasing the sim scale to compensate for the small emitter size?
        The scene scale increase was to give a bit better fluid behavior to the sim - generally rockets would be larger objects (not justa few centimeters, but rather meters) so in order to compensate for the small scale of the emitter I bumped up the scene scale.
        This makes the smoke move slower and to expand a bit more.
        Georgi Zhekov
        Chaos
